Engine DJ | 5.0 Release Notes
Hardware (Engine OS)
  • On‑device Stem Rendering for RANE SYSTEM ONE - For the first time on DJ hardware, stems can be rendered directly on the device—with no computer required.
  • RGB Waveforms on All Engine DJ Devices - Choose between Engine’s classic tri‑band waveforms or full‑color RGB waveforms.
  • On‑device Track Star Ratings - Quickly rate tracks directly from the Library or Performance views.
  • Redesigned Source Menu - The Quick Source selector and the full‑screen Source Menu are now connected, delivering a more modern, streamlined music source selection experience.
  • Pre‑rendered Demo Tracks for Stems - Demo tracks now ship with stems pre‑rendered on the following devices:
    • RANE SYSTEM ONE
    • Denon DJ PRIME 4+
    • Denon DJ PRIME GO+
    • Denon DJ SC LIVE 2 / SC LIVE 4
    • Numark Mixstream Pro+
    • Numark Mixstream Pro Go
  • Browse Encoder Turn Behavior Setting - Added a preference to choose whether turning the Browse encoder opens the library or zooms the waveform.
  • Expanded the beat range to 32 beats for Reverb Rise and Reverb Drop effects.
  • Redesigned system dialog boxes and enabled interaction using the Browse encoder.
  • Main VU meters now correctly display mono output on Denon DJ SC LIVE 2 / SC LIVE 4 and Numark Mixstream series units.
  • Album art is now stored in a dedicated folder rather than within the database file. This migration occurs when:
    • Importing tracks into Engine DJ
    • Packing or exporting to a drive
    • Running the Run Cleanup database optimization in Engine DJ Desktop
    • Loading tracks from Folder View on an Engine OS device
  • Improved Engine Lighting mixing on four‑deck devices with new crossfader‑based lighting mixing and enhanced upfader behavior.
  • Fixed an issue where headphone gain did not adjust output volume on Denon DJ PRIME 4 and PRIME 4+.
  • Fixed alignment issues between beat grids and waveforms.
  • Pressing CUE after track runout now returns the playhead to the existing cue point instead of setting a new one on Denon DJ SC5000M and SC6000M.
  • Adjusted Bluetooth device volume label text for clarity.
  • Added the ability to load a track into an empty Sample Pad when focus is on Browse or Performance Library views.
  • Tightened the Echo Out trigger point to more accurately cut the dry signal between 49%–51%.
  • Improved Amazon Music Unlimited track download speeds and switched from concurrent to sequential downloads for better reliability.
  • Reduced the time required when switching between music sources.
  • Improved Touch FX popup layout.
  • Updated Over‑the‑Air (OTA) update popups and update screen UI.
  • Refined color‑fading behavior in the Micro Deck UI.
  • Added additional padding for track length in Track Info view.
  • Fixed an issue where jog wheel displays could get stuck during initialization on Denon DJ PRIME 4+.
  • Fixed missing microphone settings on Denon DJ PRIME 4+.
  • Fixed an issue where some stems tracks did not display the stems icon when packed to an external drive.
  • Fixed an issue where Auto Loop Pad Mode would default to Bank 2 on Numark Mixstream series units.
  • Fixed missing icons for Engine Remote Library tracks in the Engine Lighting UI.
  • Improved dialog wording when connecting drives containing Rekordbox libraries.
  • Fixed an issue where selecting a new source did not always return to the Library view.
  • Fixed intermittent Browse encoder scrolling issues.
  • Fixed Engine Lighting dropouts or stuttering when loading tracks.
  • Fixed waveform overview issues for unanalyzed streaming tracks.
  • Fixed incomplete streaming track downloads on slow internet connections.
  • Fixed an issue where SoundCloud GO+ tracks were not added to History.
  • Fixed a Beat Grid Editor visibility issue in Day Mode.
  • Fixed deck indicator number alignment in horizontal player views.
  • Fixed an issue where the playhead position did not update after jumping to CUE on motorized platter devices.
  • Fixed an issue where streaming tracks were not added to Prepare when using hardware controls.
  • Fixed a crash that could occur when importing Rekordbox libraries.
  • Fixed inconsistent screen brightness behavior across some devices.
  • Fixed an issue where certain Bluetooth keyboards were not shown in the device list.
  • Fixed an issue with the Engine Lighting shortcut accessed via the settings cog.
  • Fixed missing album art in the History list.
  • Fixed an issue where track titles could fade out in Performance View.
  • Improved playlist loading times over networked players.
  • Fixed Bluetooth audio stuttering in certain environments when playing pre‑rendered stems tracks.
  • Fixed layout issues where the power‑loss pop-up text did not fit on the screen.
  • Fixed rare playback audio glitches.
  • Fixed an issue where some devices would not reboot directly into the update screen.
Software (Engine Desktop)
  • RGB Waveforms - Choose between Engine’s classic tri‑band waveforms or full‑color RGB waveforms.
  • Import Assistant - Quickly and easily import your music library from Serato, Apple Music / iTunes, rekordbox, or Traktor using a guided, step‑by‑step workflow.
  • Fixed an issue where drag‑and‑drop actions were not permitted.
  • Fixed an issue where some tracks were missing the Stems column icon.
  • Fixed an issue where the Stems processor could fail to download in certain scenarios.
  • Fixed an issue where the Stems list file size was reported incorrectly in some cases.
  • Fixed an issue where keyboard shortcuts were missing from tooltip dialogs.
  • Fixed an issue where album artwork was not displayed in History lists.
  • Fixed a crash that could occur when using Auto‑Relocate.
  • Fixed an issue where Engine DJ could fail to install after a fresh Windows 11 installation.
  • Fixed an issue where closing Engine DJ during stem rendering could cause rendering to fail.
  • Fixed an issue where the Unsupported Sample Rate dialog prevented the Stems Support Download dialog from appearing.
  • Fixed an issue where the Maintain Play State option (Engine OS only) was visible in Desktop settings.
  • Fixed an issue on macOS where certain drives could not be safely ejected.
