Hardware (Engine OS)
Bluetooth Audio Input for Supported Devices
Supported devices include:
Denon DJ Prime 4+
- Denon DJ Prime GO
- Denon DJ SC6000/M
- Denon DJ SC Live 2/4
- Numark Mixstream Pro
- Numark Mixstream Pro +
- Numark Mixstream Pro GO
Assign to any individual hardware channel or main audio output.
Assign to layer A or B on the Denon DJ SC6000 and SC6000M.
- Bluetooth transport controls allow you to play, pause, and track skip using the touch screen or hardware controls when connected to a capable Bluetooth device.
- Bluetooth Track Information displays the Track Title, Artist and track progress during playback(on capable Bluetooth devices).
Available only on supported devices listed above.
Bluetooth Keyboard Support
- Connect Bluetooth Keyboards for quicker, more efficient song searching.
- Bluetooth menu option in the Control Center allows you to connect and manage Bluetooth keyboards and audio devices.
- Available only on supported devices listed above.
Additional Bluetooth Compatibility Information
- It is recommended that you confirm the Bluetooth connectivity and functionality of your computer, smartphone, or other device before using it in a live situation.
- Not all Bluetooth devices and audio applications provide support for Bluetooth Transport controls and track information.
- Track Progress is not updated on Engine OS when it is adjusted using the originating software/app.
TIDAL Subscription Notification
- TIDAL is changing its subscription tier levels. Please refer to account.tidal.com/subscription for more information. Engine DJ OS users will be notified on login and track load if their current subscription should be updated to stream TIDAL on their Engine DJ OS device.
Software (Engine Desktop)
- Fixed an issue where Sync Manager packing would take longer if additional SoundSwitch content is being packed.
- Fixed an issue where tracks would not pack via drag and drop if there are 2 drives with the same or similar names connected.
- Various other stability enhancements and improvements
