Engine DJ | 3.2 Release Notes
Hardware (Engine OS)
  • Day Mode - A new daylight-optimized UI theme is now available. To enable day mode, open the Control Center and tap the new Layout option.
  • Fuzzy Key Mixing - The new Fuzzy Key matching option allows key syncing to the closest compatible key instead of the same key, minimizing potential large jumps in pitch.
  • FX Select - A new effect select menu for both Main and Touch FX allows for fast and easy effect selection by touching the effect name on the touchscreen. Note: The new FX select touch menu, is available for products with a single FX select knob. Coming soon to PRIME 4 and PRIME 4+.
  • Flex Gate FX - A new and improved gate effect with various gate types synchronizing to the track’s phase. This effect replaces Auto Gate.
  • Numark Engine DJ devices can now switch between Isolate and Normal mixer EQ types.
  • Downbeat detection has been improved for greater accuracy. Tracks previously analyzed must be re-analyzed in Engine DJ (desktop) to take advantage of this improvement.
  • The Play as Playlist button is now an icon.
  • Fixed a phase alignment issue for effects that consider track phase when triggering.
  • Fixed an issue where Engine DJ Remote Library would not connect after restarting Engine DJ hardware.
  • Fixed an issue where certain Wi-Fi login error dialogs would continue to show repeatedly after being dismissed.
  • Fixed an issue where the track end warning would not show on short tracks.
  • Fixed an issue where, in rare circumstances, instant doubling a track would lead to the browse knob and navigation buttons to stop functioning.
  • Other various stability enhancements & improvements
Software (Engine Desktop)
  • Downbeat detection has been improved for greater accuracy. Tracks that have been previously analyzed must be re-analyzed to take advantage of this improvement.
