Hardware (Engine OS)
Playback of 4-part Stems available on Denon DJ PRIME 4+ (other Numark and Denon DJ hardware devices will be supported in December)
Render Vocal, Melody, Bass and Drum Stems in Engine DJ Desktop
Packed tracks with Stems are found in new Stems list or indicated with a Stems icon in track list
Stems Performance Pad Mode is accessible by double-pressing HOT CUE pad mode button when a Stems track is on deck
Volume Normalization option now available for internal audio recordings
Added ability to select Lossless (FLAC) quality for Beatport / Beatsource
Improved performance of library search
Fixed an issue where “Fetching Track Info” overlay would persist after canceling a streaming provider login
Fixed an issue where Shift + turn encoder for page browsing didn’t work after selecting small/expanded view button
Fixed an issue where Engine Profile will appear as logged in after powering off and back on when there is no internet connection available
Beat Grid icon is now displayed in the top left corner when in Beat Grid edit mode
Fixed intermittent TIDAL login issues
Fixed an issue where using tap tempo on the SoundSwitch Control One could result in a crash
Additional misc. stability and other improvements
Software (Engine Desktop)
Stems rendering for later playback on Engine DJ devices
Create Stems by adding tracks or playlist to Stems list or right-clicking a track and selecting “Create stems”
Stems render support is added through an in-app download on first-use
Once rendered, Stems are included when packing tracks with Sync Manager and Drag and Drop
Playback Stems using a Prime 4+ (other Numark and Denon DJ hardware devices will be supported soon)
Fixed an issue where force ejecting a drive during song packing could cause Engine DJ to crash (force ejecting may still result in database corruptions and is not recommended)
