We are pleased to announce that Engine DJ is officially supported for use with macOS Tahoe as of version 4.3.4.
Please download and install Engine DJ 4.3.4 from our Downloads Page in order to be compatible with macOS Tahoe. Earlier versions of the software are not recommended for use with this operating system.
If you have any questions or concerns about the compatibility of our products with macOS 26 Tahoe, please do not hesitate to contact our customer support team for assistance. We are here to help and are committed to providing the best possible experience for our customers.
How do I prevent my system from updating automatically?
Please be sure to check that your operating system is not enabled to update itself automatically. While this can be a useful feature for some, anyone who relies on the stability of their software tools should prefer control over which base operating system is installed on their system.
Automatic updates will not account for software compatibility before updating, which could lead to problems with stability and other functionality if your gear is not ready for the changes in the operating system.
To avoid any delays or downtime, it's best to deliberate when making the decision to update and use the opportunity to check that all your software tools will be compatible before making the jump. To turn off automatic updates for macOS, please do the following:
- Navigate to System Settings > General > Software Update
- Click the Information (i) icon beside Automatic Updates
- Uncheck all boxes below:
- Click Done to apply the changes
