If you are new to the DJ world and are looking to build your library, then this will be the perfect guide for you.
When first starting up it's difficult to know where will be best to get your music. Well, here at inMusic we would like to point you in the right direction and advise on the available sources.
You can purchase music from various online sites, however, here is a list of 3 that provide a wide range of music ready to be purchased and used with your DJ equipment:
Note: They provide different formats which can be cheaper or more expensive depending on the format type.
Now, these sites will require you to make an account and you will need to purchase music from these sites to download and use with your Engine DJ software and equipment. However, the following streaming services can be used with our equipment to provide you vast libraries of music with streaming subscription.
See below links which provide information you need to know and how to sign up:
*Amazon Music is only available on selected products. Please see product pages for more info.
**Tidal streaming will require you to purchase the DJ extension.
Tip: Do not look to source music from an unknown entity or site as this could be unsafe or harmful. It is always best to look at getting music from a known reliable source.
If you have any questions or require any additional assistance, please contact our support team HERE.
