Numark Mixstream Pro Go | Serato and Virtual DJ support
The Mixstream Pro Go’s Computer Mode allows the user to use their device as a DJ software controller for Serato DJ Lite, Serato DJ Pro,* or Virtual DJ*.
When in Computer Mode, the Mixstream Pro Go’s touch screen offers hands-on control over library navigation, song selection, FX control, and more.
If you are running a Windows computer, you will need to download the following driver before opening Serato or VDJ.
Driver not required for macOS.
Serato support is available, as of version 3.0.8. and higher.
Virtual DJ support is now available with the latest version of the software installed.
How to enter Computer Mode on your Mixstream Pro Go:
  • Connect a USB cable from your Numark Mixstream Pro to your computer.
  • Swipe down on the touchscreen to access the Control Center.
  • Choose SOURCE
  • Tap on the Computer Mode icon to connect.
Open Serato or Virtual DJ and your Mixstream Pro Go should be recognized as a MIDI controller and as the primary audio device to output audio from your software of choice.
For further assistance, please open a support ticket.
*Serato DJ Lite will be supported for free. A paid license is required for Serato DJ Pro or Virtual DJ.
