In this article, we will guide you through the process of getting started with your Numark Mixstream Pro+ and Mixstream Pro Go DJ controllers. Whether you are a beginner or an experienced DJ, we are here to help you make the most out of your equipment.
To begin, please refer to the following steps:
1. Unboxing and Setup: When you first receive your Mixstream Pro+ or Mixstream Pro Go, carefully unbox the controller and its accessories. Follow the included instructions to set up the device, including connecting it to your computer or other audio equipment.
2. Software Installation: Both the Mixstream Pro+ and Mixstream Pro Go come with Serato DJ Lite software. Make sure to install the software on your computer. This software will not require an activation key to use with your new hardware.
3. Basic Controls: Familiarize yourself with the basic controls of the DJ controller, including the mixer, jog wheels, performance pads, and other features. Refer to the user manual for detailed information on each control.
4. Connecting to Speakers: Connect your DJ controller to speakers or a PA system using the appropriate cables.
- Main Outputs (XLR, balanced): Use standard XLR cables to connect these outputs to loudspeakers or an amplifier system. Use the Main knob on the top panel to control the volume level.
- Main Outputs (RCA, unbalanced): Use standard RCA cables to connect these outputs to loudspeakers or an amplifier system. Use the Main knob on the top panel to control the volume level.
For a visual guide on getting started with your Numark Mixstream Pro+ or Mixstream Pro Go, we have provided a helpful video below. This video demonstrates the registration, setup, and basic operation of the DJ controllers.
We hope this article has been helpful in getting you started with your Numark Mixstream Pro+ or Mixstream Pro Go. If you have any further questions or need assistance, please don't hesitate to contact our customer support team. Happy mixing!
