Engine DJ | macOS 13 Ventura Compatibility Notice
We are pleased to announce that Engine DJ is officially supported for use with macOS Ventura and Apple Silicon processors as of version 2.4.0.
Please download and install v2.4.0 Engine DJ software from our Downloads Page in order to be compatible with macOS Ventura. Earlier versions of the software are not recommended for use with this operating system.
Engine DJ Downloads
How do I prevent my system from updating automatically?
Please be sure to check that your operating system is not enabled to update itself automatically. While this can be a useful feature for some, anyone that relies on the stability of their software and hardware tools should prefer control over which base operating system is installed on their system. Automatic updates will not account for software compatibility before updating which could lead to problems with stability and other functionality if your gear is not ready for the changes in the operating system.
To avoid any delays or downtime, it's best to be deliberate with the decision to update and use the opportunity to check that all your software tools will be compatible before making the jump. To turn off automatic updates for macOS, please do the following:
1) Navigate to System Preferences > Software Update
2) Uncheck the box next to Automatically keep my Mac up to date.
