Does the Numark Mixstream Pro work with Virtual DJ?
Yes, from version 2.2 Engine DJ's computer mode has been unlocked on the Numark Mixstream Pro to allow it to control Virtual DJ via USB connection. To access computer mode, open the Source menu from the Control Center, and then tap the computer icon in the top left. You will need to be running Virtual DJ version 8.5 or later for this to be compatible.
