How do I register my product?
Products are registered to an inMusic user account/profile and give users access to any software downloads, authorization codes, and promotional content included with their product.
To register your product, please create an account or sign in to an existing account at https://profile.inmusicbrands.com.
Once you have logged into your account, select the Register Product tab.
Follow the prompts to enter the serial number as it appears on your product, as well as the date of purchase and purchase location.
Important Note - When registering hardware, you must include the (21) when entering the serial number.
How do I register software bought through a third party?
For software purchases through a third party such as Plugivery, instructions should have been included with the purchase; further instructions can be found here: How to Retrieve an AIR Music License from a Third-Party Site (Plugivery)
Where do I find my hardware serial number?
Your product serial number will begin with a (21) and will be found on a barcode sticker on the product and often on the box as well. Usually, this is located on the back or the bottom of the product, on the product gift box, and sometimes on the user manual in the box with the product.
Example:
For some unique products, the serial number may not be immediately visible. For example, the Akai Pro EWI serial number can be found on the inside of the battery panel/compartment, and many headphones will hide the serial number on the inside of the ear cup.
Given Serial Code Does Not Match Any Product
If you are receiving this error message while attempting to register your product, this means that the serial number has not been entered correctly, or the product model is not available for registration.
For hardware, please ensure that you include the (21) when entering the 15-digit serial number.
For software, please ensure you use the 30-digit serial number; you will be prompted to complete the serial number if any digits are missing.
Hardware: (21) 15-Digit Serial Number
Software: 30-Digit Serial Number
"%FIELDNAME IS REQUIRED" Error
This is an error that will only appear for users attempting to register their product with a mobile device. Please use a computer to register your product.
Maximum Amount of Registrations For This Serial Has Been Reached
This means simply that the serial number has already been registered to a different inMusic account. This may happen if the product was purchased used or gifted by another user.
If you receive this error, the serial number will need to be cleared before it can be registered to a new account. Please submit a ticket to our support team by filling out the support form here. Be sure to include your product name and serial number exactly as it appears on the product.
You Have Already Registered This Serial Code
This means the product has already been registered to your user account. From the registration page, click Back to Overview.
On your account, select the My Hardware or My Software tab, look for the Your Registered Products section, and scroll down to find your product.
Select the hardware and scroll to the Downloads section below your product access any available downloads and other content.
Akai Pro Fire Registrations
The Akai Pro Fire controller is sold in two versions: The full version includes a license for the FL Studio software, while the 'controller only' version does not include any software. This allows existing FL Studio license holders to purchase a controller for their software without the added cost of the software license.
Because the 'controller only' version of the product does not include any software, this version cannot be registered to an inMusic account.
If you are having difficulty registering your Fire controller, this is likely the 'controller only' version. Check your proof of purchase or contact your retailer if you are unsure which version you received.
Need to Deactivate a License?
If you need to deactivate a software license because you've reached your activation limit, are moving to a new computer, or are transferring ownership, you can submit a deactivation request through the inMusic Support chatbot.
Before starting your request, have the following information available:
  • The software title
  • The email address associated with the license
  • The software serial number or license key
  • The buyer's email address (for license transfers, if applicable)
For complete eligibility requirements and deactivation instructions, see: How to Request a License Deactivation for Transfer or Sale to a New User
What is the next step?
After registering your product, the majority of our products will include a download for the inMusic Software Center, where your software and activations are kept. Please see the following article for more information on this:
inMusic Software Center | How To Redeem Software Included With inMusic Hardware
Further Technical Support
If you are still having trouble after reviewing this article, please submit a ticket to our support team by filling out the support form here.
Be sure to include all relevant details, including your product name and serial number exactly as it appears on the product.
