Engine DJ Desktop | Legacy Intel Graphics Hardware Compatibility
Some users may experience startup crashes, graphical instability, or poor performance when running current versions of Engine DJ Desktop on older Windows computers equipped with legacy Intel integrated graphics hardware.
Following investigation, we have determined that these issues are not caused by Engine DJ itself, but by limitations within older Intel graphics hardware and driver packages that are no longer supported by Intel. The affected systems commonly use Intel Haswell-generation graphics processors and End-of-Life (EOL) driver releases that cannot fully support the modern graphics technologies used by current versions of Engine DJ.
Examples of graphics processors frequently associated with this issue include:
  • Intel® HD Graphics 4400
  • Intel® HD Graphics 4600
  • Intel® HD Graphics 5500
  • Intel® Iris® Pro Graphics 5200
  • Intel® Iris® Graphics 6100
These graphics solutions were released more than a decade ago and are based on architectures that Intel has since retired from active development and support.
Common affected driver versions include:
  • 10.18.15.4240
  • 10.18.15.4248
  • 10.18.15.4256
  • 10.18.15.4279
  • 10.18.15.4281
Why This Happens
Modern versions of Engine DJ Desktop utilize the current Qt 6 graphics framework to deliver improved rendering performance and user interface functionality. Internal investigation found that certain legacy Intel graphics drivers can crash during graphics rendering operations, resulting in errors such as:
EXCEPTION_ACCESS_VIOLATION_READ
The crash occurs inside Intel's graphics driver rather than within Engine DJ application code. Investigation determined this behavior is tied to legacy Intel graphics drivers that are no longer maintained by their manufacturer.
Can I Update My Driver?
In many cases, no. The affected Intel graphics platforms have reached End-of-Life status, meaning Intel no longer provides new driver development or compatibility updates for these products. As a result, there may not be a newer driver available that resolves the issue. Internal review concluded that updating drivers is generally not a viable solution for these systems.
Engine DJ Support Policy
While older computers may have successfully run previous versions of Engine DJ, they may no longer meet the practical requirements for current releases.
Because the underlying graphics hardware and drivers are obsolete and unsupported by their manufacturer, inMusic cannot guarantee compatibility, stability, or performance on these systems when running current versions of Engine DJ Desktop.
As technology evolves, software platforms must rely on modern graphics frameworks and operating system features that may exceed the capabilities of hardware released many years ago.
Recommended Solutions
If you are affected by this issue, we recommend one of the following:
  1. Use Engine DJ Desktop on a computer equipped with a newer Intel, AMD, or NVIDIA graphics processor.
  2. Upgrade to a more modern system that continues to receive graphics driver support from its manufacturer.
  3. Verify that your system is running the latest graphics driver available directly from the hardware manufacturer.
  4. If available for your workflow, continue using an earlier Engine DJ version that remains functional on your specific hardware configuration.
Frequently Asked Questions
Is this considered an Engine DJ bug?
No. Our investigation found that the crashes originate within legacy Intel graphics drivers that are outside of Engine DJ's control.
Can inMusic provide a fix?
Because the issue originates in graphics drivers that are no longer maintained by Intel, a permanent software-side fix is not always possible. Compatibility workarounds may be implemented where practical, but support for obsolete hardware cannot be guaranteed.
My computer runs Windows 10 or Windows 11. Why isn't it supported?
Operating system compatibility alone does not determine whether a system can run modern software reliably. Even when Windows itself remains functional, older graphics hardware may lack the driver support necessary for current graphics frameworks and applications.
