Numark Party Mix II | Setup with Algoriddim djay Pro on iOS
To set up your Numark Party Mix II with Algoriddim djay Pro on iOS, follow these simple steps:
Download and Subscribe to djay Pro:
Start by downloading the djay Pro app from the App Store on your iPhone or iPad. Make sure to subscribe to djay Pro in order to use external hardware like the Party Mix II. You can begin a 7-day free trial directly within the app.
Connecting Cables:
Use the included USB cable from your Party Mix II to connect it to your iPhone or iPad. Depending on the type of port your device has, you will need a compatible USB-to-lightning adapter or USB-to-USB-C adapter. It is important to use an adapter that supplies power to both the Party Mix II and your iPhone or iPad.*
*Some iPhone/iPad adapters may not provide sufficient power for your iOS device and the Numark Party Mix II. If you are only receiving LED feedback from your Numark device and are unable to control any functions within the app, it is likely that you are not supplying adequate power to both devices. For optimal performance, we recommend using a USB wall adapter with an output of at least 20W.
For more information regarding Apple power adapters, please see the following article.
Output Options:
The Party Mix II features Main and Headphone outputs for connecting external speakers and headphones. Make sure to use these outputs for the best audio experience while DJing with Algoriddim djay Pro.
By following these steps, you'll be ready to start mixing and DJing with your Numark Party Mix II and Algoriddim djay Pro on iOS. Enjoy the party!
