Numark Hardware will unlock either Serato DJ Pro or Serato DJ Lite depending on the controller or mixer you own. Here is a breakdown.
Contents
Serato DJ Pro
Serato DJ Enabled
The following list of products are Serato DJ Enabled, meaning that Serato DJ will be unlocked while your product is plugged into your computer with a USB cable.
If your product requires drivers to function, they will need to be installed before Serato DJ will recognize your hardware. If you need drivers for your product, they can be found in the downloads section of the respective product page for your product. You can click the name of your product above to access the respective product page. If you do not see drivers listed for your device or the drivers are not listed for your operating system, your product is class-compliant and no driver installation is necessary.
Serato DJ Accessories
The following products are Serato DJ Accessories, meaning they need a Serato DJ enabled mixer or controller to function with Serato. They will not unlock Serato DJ on their own.
- NDX500
- Dashboard
- NSFX
Serato DJ Lite
The following list of products are Serato DJ Enabled for Serato DJ Lite, meaning that Serato DJ Lite will be unlocked while the product is plugged into your computer with a USB cable.
- NS4FX
- Party Mix Live
- Party Mix II
- Mixstream Pro
- Mixstream Pro +
- Mixstream Pro Go
- Mixtrack Platinum FX
- Mixtrack Pro FX
- DJ2GO2 Touch
- Party Mix
- Mixtrack Platinum
- Party Mix Pro
- DJ2GO2
- Mixtrack Pro 3
- Mixtrack Pro II
- Mixdeck Express
- Mixtrack Quad
- Mixdeck Quad
- Mixtrack Pro
- N4
