How do I use Engine DJ (Desktop) to migrate/upgrade my Engine Library Database?
Simply open Engine DJ and connect your Engine Prime drive. The migration process will begin automatically.
If you are updating from Engine Prime version 1.6.1, you must first upgrade to Engine DJ version 2.0. From there, we recommend updating incrementally until you reach the latest available version.
Tip: We strongly recommend creating backups of your database before updating. This ensures you can revert and recover your data in the unlikely event of an issue.
