Can I use my current Engine Prime USB, SD, and Hard Drive with Engine DJ 2.0?
Yes, but the drive must be migrated to the Engine DJ 2.0 database first in order to mix.
Not to worry, the migration process is automatic and initiated the first time you connect an Engine Prime drive to a device running Engine DJ v2.0.
Your original Engine Prime collection will remain intact in case you need to perform on earlier versions of Engine OS.
